Customize the face on your smartwatch, Moto 360, LG G Watch, Asus ZenWatch, or any other Android wear smartwatches and learn how to directly create installable APK. Below is a simple guide on how to create new watch faces in 5 minutes.
Go to WatchfacePRO from your PC or laptop browser (Google Chrome or Firefox), click on "Generate Watchface"
Select your watchface shape. Start with a template Experts can also start with a blank template
- Choose Select your background. Your uploaded file will be displayed
- Choose Your uploaded file will be displayed adjust the size to fit, adjust it left or right, adjust it up or down
- Choose All changes made are shown here adjust the size to fit adjust it left or right, adjust it up or down
- Choose Almost there, add in a date
- Choose Enable date adjust according to your preference
- Choose If you want the same design, follow the settings as displayed there
- Final step, enable battery pointer
- Choose you are done! Just key in the details for the watchface to be sent to you
