Anyone found a way to set a reminder on the Gear S3 that is more aggressive and demands your attention. Presently, you hear one very subtle notification sound so you know to check the display...very easy to miss! It would be nice if the sound was as loud as an alarm, and the screen lit up. I haven't found any Tizen apps that will do the job either.
