GET THE LATEST TECHNOLOGY ON YOUR WRIST WITH THE XWATCH, EVERYTHING YOU NEED IS JUST A CLICK AWAY
Key Points:
Direct phone calls via the built-in speaker and microphone
Electrocardiogram readings within seconds
Super long battery life
Smartwatches have come a long way since the early days where a few neat features were all they could offer. Now, every smartwatch has the basics covered, but some are just better than others.
Take the XWatch for example. It has all the usual features you would expect from such a product, but it doesn’t stop there. Not only does it connect to your phone, allowing you to make calls and check messages, but it can help you to check in with your health and do a whole lot more.
People are starting to take notice of this clever smartwatch packed with extras.
First Impression
Most smartwatches tend to look the same and are made from similar materials. This is fine if you just want to fit in and for no one to notice the technology on your wrist.
If you want to stand out a little, you’re going to have to try a little harder. XWatch is made from quality materials and has smooth curves that give it a luxurious feel. The front and the back are cased in glass which wipes easily and looks impressive.
The comfortable strap is made from silicone and feels great when worn, making it perfect for exercise and casual use.
The Power Of A Phone On Your Wrist
When you are exercising, it can be annoying having to reach for your phone when you have an incoming call. Not to mention, the numerous circumstances where you just need to get on with the task you are undertaking.
This is where Xwatch excels, doing the basics right. You can answer calls using the built-in speaker and check messages, even speak to your calendar to set reminders. You can check your call logs and even set an alarm.
The touchscreen display is easy to navigate thanks to the 1.54 display.
Your Exercise Companion
A smartwatch should be used properly, after all, if you don’t use the features it is no better than a watch.
Part of the problem is that out of date smartwatches don’t have a lot to offer. XWatch is known for being great for your health. Because it can monitor heartbeat and connect to your music via Bluetooth it is a brilliant gadget for staying in shape.
Use the pedometer to track your steps and distances and connect to apps to read and display fitness data so you can track and challenge your personal bests. You can even look at live ECG diagrams so the exercise features are perfect for anyone who wants to be healthy.
These diagrams can give you a physical examination that is otherwise hard to achieve. It only takes a minute and if you are feeling chest pains or aggravations you can show them to your Doctor.
It allows you to check your resting heart rate as well as during exercise.
Battery To Last As Long As You Do
This is especially important if you are looking for a smartwatch you can use it for exercise. The last thing you want is for the watch to run out of battery halfway through a run, losing the motivating music you are listening to.
XWatch has this covered with a massive 3-5 days of battery life depending on usage. On top of this, it only takes 1 hour to charge via USB which is better than most of the competition. This is all because of the 380mAh battery that is just another sign of its quality.
Vibrant Display
Your smartwatch is only as good as the quality of the on-screen display. Some of the options on the market just aren’t as good to look at which takes away a lot of the enjoyment.
The LCD display is unnoticeable on the XWatch when not in use but when it is, the colors are clear, making it easy to read your messages when on the go.
Excellent Value
Because smartwatches have been around for a while, there are more options which means you don’t have to break the bank to get your hands on one.
Still, there are plenty of low-quality products so you need to be careful. These aren’t reliable and they don’t give you a lot of useful features. XWatch represents a great opportunity to purchase a powerful smartwatch with all the latest features that can make life easier.
Not to mention the fact that all the fitness-related additions that can improve your health and encourage you to get moving.
Wherever you go, XWatch can follow, and when you start to use the features, you’ll be glad it did.
Where can You purchase the XWatch?
XWatch is available for a limited time only, with exclusive offers and free shipping.
Ordering is quick and easy, so take advantage of the great price by ordering yours today.
